Ability to change model/measurement units
Please allow the option to change a model’s units along with the measurement units.
If it is only the difference between meter and millimeter it is not that big of an issue. But the last couple of days I had some models in imperial and that is just unworkable!
I believe the origin of those models are all RVT exports out of Inventor, which does make sense that they would be imperial. I could open them in Revit first to change the units before importing into Qonic. But that is very time consuming, certainly when I only find out after having done some corrections in Qonic already…
When it comes to display/measurement units in the viewer, they change with the active model. So I can agree with that and it certainly is not as much of a priority to me to make those independent. But at a certain point in time, it would be nice if that could be a user preference. For example many Architects (and probably contractors as well) in Belgium are using cm by default. I have a preference for mm and a surveyor will likely prefer m. We can all read those units but sometimes it can be a bit confusing when making a measurement for something that we don’t know the size of if “5000” is in mm (thus 5m) or in cm (thus 50m).
@Johan_De_Cock, FYI your user request is now under development and will be added to Qonic in an upcoming release. Regardless of the system and unit defined in the model, you will be able to switch between the measurement system (metric/imperial) and unit (e.g. for length: metres, centimetres, millimetres, feet, inches). This will initially be a project and model setting rather than a user preference.
Thanks @Dieter !
Just for certainty, when you mention “Project and model” setting, I am a bit confused. I’d say it is one or the other, no?
Or would the project setting only be to set a default for newly created models inside of Qonic?
The idea is that you can choose a default system for your project, such as the metric system. If you upload a new model and the imperial system is not wanted, you can choose to convert that model to metric. Alternatively, if you wish to keep the imperial system for this one model, this is still possible.
Perfect! Thanks for the clarification
