Components / component editor
Hi, I have a couple of things I’d like to addres related to ‘components’ and the component editor:
  1. I really like that updating a component definition doesn’t necessarily mean automatically updating all instances. It is an active choice to update them.
  2. When doing this, based on the release video, it looks like there is no option to “keep current as a new variant”. What I mean by this: Let’s say we want to update a certain furniture element in the component editor. Then we come back to the model and notice that instead of the 10 instances we new about, there are 5 more somewhere hidden that need to remain the ‘old’ design. Then I’d like to be able to select those and create a new variant based on the ‘old’ version of the component.
  3. From inside the component editor, I’d like the option to “save as variant”. And maybe switch between variants of the same component. Now we have to go back and forth to the model environment.
  4. When creating components based on the geometry in the model, I think there is a more logical way. Right now: we select an element, right click => create component. Then we have to go to the component definition and “find unlinked products”.
    I’d like to: select an element, use “find same …” to select all instances of that element, then create the component. That way it can all be done from within the model environment without needing to go into the sidebar (at least until the creation of the component itself).
  5. I am a bit hesitant about the ‘publishing’ workflow. Just as with 2D drawing creation I think it is a big step to ‘have to’ publish before being able to use the component in the model. It makes sense when the model editing is done by another person than the drawing creation or component creation. But not when it is all done by the same person. It interrupts the flow of the moment, in my opinion. I should be able to insert the changed component directly into my active model.
  6. Love the concept of “refence geometry”! I suppose this can be anything? Any class? In any shape? That is a huge difference/step up compared to the family editor in Revit which is very rigid.
  7. Are we going to be able to create ‘production’ drawings on component level? For example for furniture as displayed (kitchen design). But could be expanded to prefabrication of steel/wood/concrete elements?
  1. Glad to hear! Me too
  2. Good idea, we’ll add this capability soon
  3. When editing a component, open the model picker (arrow right next to the name of the variant in the top bar). It shows all variants, you can switch between them or visualize multiple at the same time. The variant names have a three dot menu, with an option “Duplicate” - so you can first duplicate, then make changes.
  4. Makes sense as well, we’ll have a look.
  5. Completely agreed: that is the goal, it’s just going to take us a bit more time.
  6. Yes
  7. In time, yes, though the focus is on general arrangement drawings first.
Thanks a lot Pieter! Good to hear your vision supports our needs :slight_smile:
Another question related to components: the link with “Properties”/“Parameters”/“Metadata”
Because of a radically different approach to the components compared to Revit (or other classic BIM modelling apps), currently there is no link between geometry of the component and certain properties.
  1. Is it already possible to define (type level) attributes/properties for the components and their variants? Naming is the first that comes to mind and is covered. But what about ‘geometric’ data?
  2. In Revit (sorry for the comparison so often) a ‘variant’ (=type) can be defined purely based on the parameters and constraints. A door for example can get a new type simply by typing a different width/height.
    Qonic has the opposite approach: we can easily manipulate the geometry. In some cases that is preferred. In others (or maybe it is more a matter of habit) I think the parametric method is preferable.
For an example like doors/windows, for me the geometric parameters are very important. And I don’t think they all have geometric representation and/or IFC properties. For the width for example there are at least 3 important widths, they are all different:
  • Width of the opening in the wall => necessary to make the wall to the correct dimensions
  • Width of the outside of the frame and/or width of the door itself (depending if it is an exterior or interior door) => for interior doors there are standard sizes 730, 780, 830, …
    This is important that the user doesn’t get to choose just any size. They can be made to measure if needed but become much more expensive!
  • Width of the clear opening for evacuation => in Belgium this must be at least 800mm in a position where the door is 90deg opened (not more, even if the door CAN be opened further).
When using a parametric component we can choose one of these as an input (for interior doors, that is always the door itself). Then we can use formulas to calculate the others. And this is used both to create the geometry (opening element) as for reporting (clear opening).
How do you see this to be incorporated into the Qonic components in the future?
Smaller point related to components:
When creating a component from the model, it is required to select a component library. When there is no library defined yet, I have to exit this window, go to libraries, create it, then come back and repeat the first action I made:
Can a button be added to create a Library from within this window?
Another small discrepancy:
The text says: Create components from scratch or upload Revit family files. But there is no button to create one from scratch (yet).
It’s currently not possible to define properties at the component definition level. However, you can create properties on the top level product in a component variant. Here you can use dynamic properties that could calculate, based on formulas and the geometry, the different widths of a door for example. For now, they will all be derived, none input.
Meanwhile we are working on our vision on parametric components. You will be able to define input parameters that define the geometry of the component variant.
