Georeference management
As discussed in this topic: Question related to Georef workflow
Currently there is no option to alter/reset/… the project’s georeference. Yes we can alter the Survey Point manually. I understand that it is difficult to create a whole suite of tools. I couldn’t say what I’d need on a regular basis if you’d ask me.
The most simple solution - and the first to implement - I’d say would be a method to reset the georeference of the entire project. Then the next time a new model (or model revision) is uploaded, the information from that model would be used to set the georeference again.
=> This would have as advantage that we could start a project without georeference (only local reference/coordination on a mutual point). Then after a while once we have the correct information we could create an empty model (or with some dummy geometry) that has the correct georeferencing. And from then on, that would be the new default for the project.
Thanks Johan, this is a known limitation. There’s currently no way to reset the georeference of a whole project: as explained in Question related to Georef workflow , it’s set by the first georeferenced model or survey point, and after that it can only be changed by editing the survey point. We’ve logged a request for a reset, so the next uploaded model or revision sets the georeference again, and it’s under consideration. We’ll update this topic when there’s news.
