In case of changes in models, we have the option to “Discard changes”. But how do we do this for changes on the project level? I don’t see it in the publishing window. And no idea where I could look for it elsewhere.
Hello Johan, discarding all changes, including the project data is an option when you click on the ellipsis (the three dots).
thanks Dieter, I didn’t know about that option.
But that would discard the model changes as well, I presume?
hello @Johan_De_Cock , you can select and deselect a model to exclude it from the publish process. In this example I excluded the second model out of three. You can’t deselect ‘the project data’.
Thanks Dieter.
It confirms the point of my post: discarding project changes is only possible if we also discard all model changes. I’d like to have the possibility to discard project changes alone, in the same way as the discard on model changes.
Hey Johan, it’s a safety feature to not be able to do so. E.g. you create a project location library (=project data) and link objets of a model to that library (=model data). The data becomes corrupt when you delete the project data. The link still exists but there is no location library. The solution is to publish often. This allows you to be able to discard project data without the need to delete the work you did in your models.
