Currently I don’t find any good method for importing a material library into Qonic to start modeling from there.
I can import a RVT file, that will create a model library with the materials that are used in the model (not all the materials in the Revit project though). That is a good place to start. But I cannot promote this model library to a project library.
Then I tried if I could go into the model and start creating materials in a new (project) library. But I cannot take over any elements from the existing materials (name, appearance). So that leaves me with only one option: create the library again from scratch.
This topic is linked with other topics in the community:
Hi Johan, promoting a model library to a project library is part of the library management work we’re looking at. We’ve added your use case to it, together with the earlier topics on merging model libraries ( New "Merge" tools for model libraries ).
Happy to report that in the upcoming release it will be possible to copy library items from one library to another, so even without the ‘upgrade to project library’ functionality it should already be possible to select all materials from the imported library and copy them into a new project library.
Good to hear this small improvement is coming up! It will be useful to at least save some time if we want to create a project library!
Related to the import of (Revit) libraries: It would be good to have either of below possibilities (similar to RFA import):
Either in the library manager have the choice to import library from RVT (using all material definitions, not only the materials that are assigned to products)
Or on import of an RVT file as a model have the same options to import all materials, not only those assigned to products => less desirable I think but maybe easier to implement?
Thanks Johan, that is useful input. We have noted your suggestion to import all material definitions from an RVT file, not only the ones assigned to products, similar to how the RFA import works. We are looking at this together with the other library management requests and will update this topic when there is news.
