When I replace a wall structure, the new structure is always aligned to the reference line of the original wall. With “Align on” I can choose whether the whole new structure or a specific layer is used for alignment, and “Alignment” defines which side of it (left / centre / right) is placed on that reference line. However, the target on the original wall is always its reference line, and I cannot choose one of its faces instead.
This is a problem when replacing a single-layer wall with a thinner multi-layer wall, because single-layer walls have a centred reference line by default.
Example: An external wall is modelled as a 30 cm single-layer placeholder and is replaced with a 20 cm multi-layer element wall (5d_BFT_Elementwand_20cm). The external face must stay where it is. Since the new structure is aligned to the centre line of the old wall, the external face moves inwards by 5 cm. The reference line of the original wall itself cannot be changed. I can only change how the wall is aligned to it, which moves the wall. So the only workaround is to realign the original wall and then move it back to its correct position before replacing. This adds extra steps for every wall and is not practical for bulk replacements.
Expected behaviour: In the Replace dialog, I can also define the alignment target on the original wall, not only its reference line. Since a wall has no defined exterior or interior face, the target should be defined by side:
- Side selection: I choose the left side, reference line or right side of the original wall, relative to the direction of its reference line (consistent with the existing Alignment logic). This allows replacing many walls in one step.
- Preview and flip per wall: Since walls in a model are often not drawn in a consistent direction, “left” can be the exterior face for one wall and the interior face for another. A preview should show the target face for each selected wall, with the option to flip it for individual walls before applying.
- Pick face (optional): For single walls, selecting the target face directly in the 3D view would be the most intuitive option.
Combined with the existing options, this would allow, for example, “align the outer face of layer Beton – Stb.Wand 8 cm to the selected side of the original wall”, so that this face stays exactly in place.
