View/alter/... the true north vs project north angle
Currently we see the direction of North, relative to X/Y axes. But we cannot see how much this angle is. Neither can this rotation snap to any of the geometry, nor can we measure.
When starting from scratch this shouldn’t be much of a problem. We can rotate starting from North = Y axis. But if there is already something set up and we want to correct this. Or simply validate if the angle is correct, or use it somewhere else, … we cannot get the correct number.
Hello Johan, you can select the survey point, start the Transfer tool and rotate the survey point until it snaps to an object that is placed along the XY axes. In this example the angel between North and Y axes is 31,7°.
This should solve your question.
I tried that … Must have done something wrong.
Hi Johan, I wanted to follow up: did you manage to change the north angle with the survey point in the end? If not, let us know which step doesn’t work as expected and we’ll help you further.
