Alphabetic / Numeric sorting algorithm
Today I created a report using the typical “Mark” property as only grouping parameter.
In this case, the Mark is completely numeric (though no doubt it is a string type parameter in the backend). Which means that when sorting alphabetically, I got something like: 1, 10, 11, …, 2, 20, 21, …, 3, 4,
I know I can solve that by using a leading zero. Which we often do for things like naming conventions, when the value is a combination of letters and numbers.
Can you please update the sorting algorithm to recognize numeric values? In the perfect world it would even work in a combination of numeric and alphanumeric values. But if it already works when it is only numbers, that’s already worth a lot.
Great suggestion. We updated the sorting algorithm to use the natural sort order, meaning that we treat each number part as there numerical values. So even a combination of numeric and alphanumeric values should get an intuitive order.
Great, sounds perfect!
