Another question related to the georeferencing. One that also Hans Lammerts has commented about on another forum.
How is the height level defined?
I tried a model that has a correct X/Y implantation using Lambert72 (EPSG: 31370). It shows on the correct location with the Cesium tiles.
However for the height there is a difference of about 1.5m. I don’t know the exact level of the current terrain, but I know that our foundation is supposed to be +/- flush with the current terrain. And that difference I figured out with some box geometry to be +/- 1500mm.
Hans commented that it could likely be that the 3D tiles are using WGS84. It looks like for the X/Y transformation something is in place to transform from another CRS (like Lambert) to the WGS84. But since those CRS have no information about height I assume that is the reason no transformation is made?
I tried again with another model today to do something about the height reference.
Even using the correct hybrid goeref system EPSG:6190 (LB72 + Ostend Height) there does not appear to be a transformation in place to correct the height of the model.
In this case, the Ostend Height value is 19m. When I calculate using CConvert from LB72 → LB2008 and than on to WGS84 (which I presume is the georef system Cesium uses), I get at a heigt of 61.6m for the same location.
No matter what I do to set this as the “height” of the survey point, it doesn’t change anything. Only thing that fixes it is to move the entire project to +61.60m. Even then, it is not perfect (which could have a lot of different reasons). But I do think there is one thing that Qonic should be able to do: make the correct tranformation from the given coordinate system to the one that is used by Cesium. So that we can keep using the local system (Ostend Height / TAW) but the 3D tiles are represented on a representative level.
Just completed one more test. If I use the EPSG: 8370 (LB2008 + Ostend Height) and correct the Easting and Northing to correspond to LB2008 instead of LB72, the “Height” correction of the survey point does have effect.
So it appears it is more of a problem with EPSG: 6190 (and/or LB72 coordinates) and less of a problem because of Qonic/Cesium integration.
Just sharing some experiences now:
In another project, we use the TAW (Ostend Height) levels as the local Z level coordinates. So in this project I have circumvented the issue by placing the Survey Point on a height that corresponds with the difference between Ostend Height value and the WGS84 height for the same coordinate.
In this project, the Cesium tiles are ‘transformed’ in the Z direction to correspond to the height level of the Survey Point. This, together with the Ostend Height as ‘internal’ height reference system make for a correct representation of the surrounding area (and 3D tiles).
=> I verified the coordinates and height transformation for this specific point using CConvert again, the difference was <1mm (might be because I rounded the X/Y coordinates in the first input step).
Hey Johan,
thank you for your detailed explanation. It really helped us pinpoint the issue. We’re currently working on a fix!
Great! Looking forward to the georeference options working better
