Possibility to easily isolate (hide/grey the rest) selected element/group. Best way with right click menu or shortcut.
Hi Sasa,
You can hide/isolate elements using the Scope functionality. Search for Scope in the command bar, use the buttons on the right hand side or using the shortcuts: - for remove from scope (hide), + for set as scope (isolate), and * for reset scope (show all). This will also be added to a right-click menu soon!
