Toggle layer on and off, and the option to make layers transparent
Thanks for the screenshot, Franz. Today a single layer of a wall or slab cannot be switched on or off, or made transparent, by itself. Hiding and transparency work on whole parts. Sections and Scope shows how to hide parts with ‘Remove from Scope’. If you split a wall into layers first, each layer becomes its own part, so you can hide the ones you do not need. Making single parts transparent is close to the request in Temporary Transparency. Thanks for your request, and we will investigate it.
