Hi Franz,
Loading a second SKP file into a model that already has one isn’t possible yet. But, you can work with several SketchUp models together. When you import an SKP file, Qonic converts it into an IFC model in your project. So you can upload as many SKP files as you like to the same project and open them together in one session with the model picker: Model Picker | Qonic
More, you can copy entire model into another one in multi-model session, or just copy one part of the model to a newly created one. See Inspect Panel | Qonic
Tokens are only used by Qonic AI, so importing an SKP file doesn’t consume any. The November release notes explain how tokens work: Qonic November Release Notes 2026
Regarding a live link between SketchUp and Qonic, this will be added to our feature requests list but I cannot tell you if and when it will be done.
