Where BIM loses time, and how Qonic will give it back
Most BIM teams don’t struggle with capability. They struggle with overhead.
As models grow over the course of a project, so does the effort to manage them. Coordination takes longer. Clash checks multiply. And the software starts to feel like an obstacle. At some point, progress feels slower not because the project is complex, but because the workflow is.
The upcoming developments in Qonic in 2026 are driven by a simple question: How can we stop time quietly leaking out of BIM projects?
The answer doesn’t lie in one big feature, but in four strategic shifts:
  • Autonomous Quality: Moving from reactive manual checks to intelligent, self-examining models.
  • Fluid Ecosystems: Breaking down silos with open APIs and live geometry streaming.
  • Native 3D Modelling: Bringing professional 3D design directly into the coordination context.
  • Radical Collaboration: Replacing collaboration guesswork with clear, ISO-aligned ownership.
Each of these shifts is grounded in concrete changes coming in early 2026.
1. Less manual work, more automated certainty
A surprising amount of BIM time is spent on manual work, confirming things that should already be correct. Are elements correctly classified? Did something break when another discipline updated their part? Traditionally, BIM quality is reactive: you model, you inspect, you fix.
With Qonic, we are flipping that rhythm. Instead of quality being a final hurdle, it’s an intelligent, persistent layer that runs in the background.
Instead of manual inspection, Qonic introduces autonomous quality control: models that self-examine in real-time, assemblies that instinctively recognize inconsistencies, and AI-driven validation engines that flag suspicious quantities long before a report is generated.
Upcoming Intelligence in Qonic 2026:
  • A new Quality Hub brings checks for classification, interferences, non-split walls, component consistency, and suspicious quantity outputs into one place.
  • Rule checking, supported by AI-based classification to flag inconsistencies earlier.
  • Tools to find and select similar geometry or assemblies across a project, copy and replace details safely, and reuse data without breaking structure.
  • Natural language queries are introduced, allowing users to ask the model for information or actions without navigating complex menus.
What this changes in practice:
  1. Designers no longer have to manually verify basic correctness after every change.
  2. BIM coordinators spend less time preparing and filtering reports, and more time focusing on real coordination risks.
  3. Contractors gain earlier confidence in quantities and assemblies.
2. An ecosystem, not a closed tool
No real project lives in one single tool. Geometry might come from one place, analysis from another, planning from a third. The problem is rarely the tools themselves, but in the friction between them.
Qonic is positioning itself as part of a connected ecosystem rather than a standalone tool. By opening up APIs and supporting live connections with other software, Qonic becomes a central place where models and data stay accessible and up to date. External tools can connect directly, and geometry can flow without repeated exports and imports.
Some upcoming features in Qonic 2026:
  1. A public Workspace API that allows third-party applications to connect directly to Qonic through the dashboard
  2. Live geometry streaming via API, making it easier to view and work with Rhino, Revit, geospatial data, or point clouds inside Qonic
  1. Design teams can keep using their preferred early design or scripting tools while maintaining a live connection to the coordination model.
  2. Coordinators no longer spend time reconciling versions from different sources.
  3. Contractors connect downstream tools directly to Qonic via the public API for planning, simulation, or reporting.
3. A full 3D BIM modeler
As projects progress, the line between modelling and coordination fades. Small changes happen late, details need adjusting, and switching tools for every minor edit is a productivity killer.
We are bridging this gap by maturing Qonic into a full-scale 3D modeling environment. Modelling becomes something you do directly within the coordination context. Powered by our own geometry kernel, Qonic 2026 makes it practical to sketch, edit, and maintain complex architectural, structural, and MEP elements without leaving the platform. It’s about making the model a living, editable asset from start to finish.
  1. A more complete modelling set, powered by Qonic’s own geometry kernel.
  2. The ability to start new projects from a blank model, sketch and edit geometry with improved snapping and selection, and work more consistently with architectural, structural, and MEP elements
  3. Reusable components with variants and version history, making updates safer and clearer
  4. Full support for openings, spaces, and assemblies
  1. Designers can make design changes directly in the environment where coordination happens.
  2. Coordinators can resolve small issues themselves instead of sending changes back and forth between tools and teams.
  3. Contractors receive clearer and more consistent models, reducing downstream rework.
4. Collaboration at the core
At Qonic, we thought a lot about improving collaboration, one of the main causes of time loss in BIM projects. BIM is, at its heart, a shared effort where multiple firms contribute models to create a single buildable reality.
For that to work, three things must be true:
  1. Shared intent: everyone is working towards the same outcome
  2. Clear contribution logic: who models what, to what level, by when?
  3. Ability to act: access to data, ownership, and timely decisions
Tools can’t fix misaligned intent, but they can actually help and influence collaboration by making misalignment visible and harder to avoid. They can help make ownership clear, and clarify what can be acted on and what cannot.
Qonic’s collaboration direction focuses on making project state visible and predictable, especially in multi-party projects where delays happen.
  1. Clear project versioning aligned with ISO19650 concepts such as work in progress, shared, and published
  2. Review and approval workflows are built into the platform instead of managed externally.
  3. Saved selections allow teams to reuse sets of elements for checking, reporting, planning, or review.
  1. Designers always know whether they’re working in a draft, shared, or published state.
  2. Coordinators get clearer review and approval workflows aligned with ISO19650 concepts.
  3. Contractors gain better visibility into what is stable enough to use for planning, quantities, or construction simulation.
Why this matters in everyday work
The changes coming to Qonic in 2026 are about stopping loss of time. It’s about quality checks that happen in the background. Models that stay connected. 3D changes that happen where the coordination is. Collaboration made visible and predictable.
On top of that, Qonic brings 2D drawings into the same connected workflow. A new 2D viewer allows teams to generate and inspect drawings directly from saved model views, including automated annotations and dimensions.
Also planned for 2026 is a 4D planning toolset. Tasks can be created directly in the platform and linked to elements in the 3D model. This allows construction teams to explore sequencing, visualize progress over time, and discuss planning issues using the model itself, instead of detached schedules or spreadsheets.
For designers, coordinators, and contractors alike, Qonic’s 2026 direction is about one thing: spending less time managing the process, and more time moving the project forward.
That’s what Qonic’s roadmap is really about. Making BIM more supportive of daily work, and giving BIM teams something valuable back: focus, confidence, and time.
We’re building the BIM environment we always wanted. Which of these four shifts would impact your daily work the most? Let’s discuss in the comments!
