Hi Franz,
Not yet for 3D solids: once a box or other solid is created, you can’t change it through its parameters anymore. We are working on parametric components, where input parameters drive a component’s geometry (see Components / component editor). Parametric solids with dependencies and rules like in HiCAD aren’t part of that yet, but I’ve shared your request with the team.
2D primitives don’t work as described in the help and also have many significant limitations:
Converting to curves only works for individual lines, not for polygons or rectangle outlines
(the video in the help shows something different)
Lines from polygons and rectangles cannot be modified—no inserting points, no deleting lines
Lines and rectangles can only be modeled on the XY grid or on solids
Polygons cannot be edited, e.g., if I want to model or modify a stair profile—again, only on solids and grids (vertical grids are not possible even with angle rotation)
Is all of this correct? Have I missed something? If everything is correct, please quickly add more functionality, as modeling is not fun like this!
Best regards,
Franz
PS: I’m truly convinced by Qonic, but there is still a lot missing for productive use!
It would be great if I could copy and paste geometries from SketchUp into Qonic
And really, check out SketchUp!!!
Drawing lines and rectangles is indeed limited to the XY plane and faces of solids today, and converting polygons and rectangles to curves doesn’t work like it does for single lines. I’ve added both to the request we already have open for consistent creation and editing of 2D shapes and 3D solids.
Copy and paste from SketchUp isn’t possible today. I’ve shared it with the team as well.
About the help video: could you tell me which page you saw it on? If converting a polygon or rectangle really should work there, it’s a bug.
