Qonic February Release Notes 2026
This month marks a new beginning. We’re giving you the freedom to start fresh without imports. We’ve also refined the interface to keep your hands on the tools and less on the menus. Whether you’re sketching your first wall or fine-tuning a complex model, everything is designed to feel more direct and responsive.
Watch the full release webinar:
Create new models from scratch
You can now create brand new models directly in Qonic. Each new model comes with a surveying setup on a tripod to help you orient yourself and easily locate the local origin. This is the foundation you need to go from concept to construction without leaving the platform.
Sketch Grid
We’ve added an adaptive sketch grid to the XY-plane that gives you a clear sense of scale and direction while modelling. The grid automatically adjusts its intervals as you zoom in or out, and supports snapping during modelling operations. Toggle it on or off anytime via the Sketch Grid button in the bottom toolbar.
Redesigned User Interface
To minimise mouse travel and speed up your workflow, we’ve restructured the interface. The action toolbar has moved to the bottom of the screen, putting your most-used tools within easy reach. We’ve added a quick snapping toggle for faster access, and relocated view settings and toggles to the right-hand side. The result? Less hunting, more modelling.
Deep Select improvements
Working in Deep Select mode is now clearer and more responsive. We’ve added a UI button for easy switching between boundary and face selection modes. We also removed the dark background change that used to happen in Deep Select mode, so your view stays consistent and you can focus on the geometry, not the interface.
Modelling & Geometry
  • Add Layer enhancements: Fixed for curved boundaries and corrected thickness scaling when working across multiple models
  • Section box improvements: Adapted view and cut plane offset for generated section boxes, plus fixes for building rotation and view distance. Visual improvements for clearer feedback during section creation
Measurement & Quantities
  • Immediate reselection: After previewing quantities in Measure mode, you can now immediately reselect without extra clicks
Revit Integration
  • Shared origin alignment: Revit imports now align correctly based on shared origins, improving accuracy when bringing in multiple Revit models
  • Export as New Model: Added export button for family instances
  • Material support: Export now includes materials for family instances
  • Fixed material loading: Resolved issues with loading materials from families
Data Management
  • Personal version control: Import and delete operations now work correctly on personal versions
  • Hidden deleted models: Models marked for deletion in personal changes are now hidden from view until published
  • Clash detection fix: Removed all previous selections when showing clash detection visualisation
API
  • Dynamic fields query: Added new endpoints for querying dynamic fields via the public API
Stability and Workflow Fixes
  • Smoother external user invites: Adding external users is now more streamlined
  • Request access reinstated: The request access to project button is now visible again when needed
  • Model library deletion: Deleting model libraries now works as intended
  • Role changes: Fixed issue where changing user roles would not take effect immediately
  • Security update: Updated React framework to address a major security issue
  • Publish button visibility: Fixed issue where publish button appeared when no project was active
  • Onboarding experience: Resolved issues with onboarding movies
  • Removed inline library creation: Streamlined library management workflow
That’s February. We’ve given you the tools to start fresh and work faster. Now it’s your turn to build something. Log in and see how the new workflow feels.
Want to know where we’re heading? Our co-founder Erik recently shared his vision on BIM 2.0 and what’s coming next. Read it here.
