Accurate Quantity Take-Offs (QTOs) are essential for cost estimation, material planning, and efficient project management. Yet, many professionals still face time-consuming, error-prone workflows due to disconnected tools and manual processes.
In our latest webinar, Quantity Take-Offs Made Easy, we revealed 9 key strategies that make QTOs more intuitive, accurate, and efficient using Qonic’s fully integrated workflow.
Missed the webinar? Watch the full session here:
The Challenges of traditional QTO Workflows
Today, modeling and Quantity Take-Offs are often handled separately, leading to major inefficiencies:
- Lack of synchronization – Model updates don’t automatically adjust QTOs.
- Incomplete data – Missing attributes make accurate take-offs difficult.
- Limited tools – Measuring handrails, gross/net areas, or complex elements can be frustrating.
- Time-consuming validation – Unclear measurements lead to unnecessary double-checking.
How Qonic solves these problems
“Qonic offers a fully integrated QTO workflow that ensures accuracy, efficiency, and collaboration.”
These 9 key features help professionals streamline their Quantity Take-Off workflows:
1. Flexible material quantification
Qonic lets you choose how to quantify materials. Need a net area for the entire wall? Or a detailed breakdown of insulation, bricks, and finishes? With full control over measurement methods, you can tailor QTOs to your project’s specific needs.
2. Create new geometry with ease
Easily add missing structural elements with push-pull modeling. Insert a lintel, define materials, and integrate it into your model. You can also copy windows and their lintels to multiple locations—saving time and ensuring consistency.
3. Real-time quantity updates
No more manual recalculations! Qonic dynamically updates all quantities in real-time, ensuring accurate, up-to-date take-offs as your model evolves.
4. Instant wall connection fixes & higher Level of Detail
Properly connected elements are crucial for accurate QTOs. Qonic enables batch-fixing of wall connections, ensuring all materials are correctly recognized. If an issue arises, you receive an alert to manually adjust it, preventing costly errors.
5. Visual feedback & instant element location
Understanding your quantities has never been easier. With direct visual feedback, you can see how changes affect QTOs, making verification fast and reducing errors.
Qonic highlights elements and openings, including insulation, facing bricks, and other materials, so you always know what’s accounted for. Need to find a specific element? Click on a report entry, and Qonic will visualise its exact position in your model.
6. Take quick measurements with the Laser Tool
Quickly measure heights, widths, and distances with Qonic’s Laser Tool. Whether checking a door height or beam span, this tool makes on-the-fly calculations effortless.
7. Define custom color overrides
Highlight specific elements with color settings to improve visualization and organization of material quantities. This makes spotting patterns, detecting errors, and analyzing take-offs much more effective.
8. Generate comprehensive Quantity Take-Offs
Produce fully detailed QTO reports with just a few clicks. Qonic ensures that stakeholders receive structured, actionable data, whether it’s a general quantity report or a detailed window/door breakdown grouped by fire rating and width.
9. Support for Classification systems & standardized QTOs
Qonic supports Uniclass, NRM, and VMSW classification systems. Import classifications via spreadsheets or an API connection to the buildingSMART Data Dictionary. If elements are already assigned classification codes, you can filter and organize reports effortlessly.
A complete & collaborative QTO Workflow
Qonic isn’t just for take-offs—it’s a fully integrated workflow. Start with an IFC or Revit file, then:
- Add missing data
- Create additional geometry
- Extract accurate quantities
- Share results or export seamlessly
And because Qonic supports a multi-user environment, your team always works with the latest version, eliminating outdated data and miscommunication.
The quick win of QTO
A well-structured QTO saves hours, if not days. With Qonic’s precise, reliable take-offs, you reduce errors, optimize workflows, and improve project efficiency.
Missed the webinar? Watch the full session above to see Qonic in action. Want to experience these powerful features yourself? Try Qonic’s QTO workflow today!
