Qonic April Release Notes
We’ve been working on some major updates for Qonic, and we’re proud to bring you a release that adds real value to your BIM workflows. This April update is packed with tools to help you manage projects more smoothly, catch issues earlier, and model with more control and precision. With features like Clash Detection, QI Smart Filters, and the new Union Tool and Merge Procedure, there’s a lot to explore. Check out our Release Video or dive straight into the release notes.
  • Union Tool & Merge Procedure: Effortlessly combine multiple elements into a single geometry, ideal for cleaner and faster modeling.
  • Split Geometry Procedure: Divide complex volumes into manageable parts without losing control or precision.
  • Improved Manipulator: Enhanced visuals and more intuitive hitboxes for smoother interaction while modeling.
  • Laser Tool Enhancements:
    • Better highlighting of aggregate objects
    • Highlight now visible during and after object placement
    • Smarter repositioning of dropped elements
Data Management
  • QI Smart Filters: Introducing QI, Qonic Intelligence, our machine-learning powered classification and filtering system. QI automatically analyzes object geometry and contextual cues to detect and classify elements in your BIM models, eliminating tedious manual tagging and guesswork. Once classified, leverage intelligent filters to quickly explore, refine, and manage your data, ensuring cleaner and more structured information.
  • Improved Surface Area Calculator: Optimisations improve performance and precision when calculating surface areas.
  • Improved Thickness Estimation: More accurate detection and presentation of thicknesses across geometry.
  • Browse Panel - New Filtering Options:
    • Added “Not Assigned” as a filter option for better data scoping
    • Faster Browse Panel: The property picker now loads properties on demand instead of loading everything up front.
Platform & User Interface
  • Smoother Library Panel Navigation: Navigation and interaction within the Library Panel have been improved for a more responsive experience.
  • Create Libraries for every type: You can now create new libraries per type, enabling better content organisation.
  • Extended Material Properties: Additional properties have been added for materials, giving users more detailed control.
Coordination
  • Clash Detection: Qonic’s new Clash Detection feature helps you identify and resolve spatial conflicts in your model early on. It detects geometric clashes, such as overlapping elements, and clearance clashes, ensuring there’s enough space between objects like ducts and structural components. Additionally, the feature highlights conflicts between structural and MEP systems to avoid coordination issues.
  • Issues Panel + Notifications: Raise issues directly on your model, assign them to team members, and add comments and snapshots for full context. Track progress with status updates and receive real-time notifications to keep everyone aligned and problems resolved quickly.
API
  • New API Features:
    • Added DELETE product functionality
    • Added support for assigning previously unassigned properties via API
Bug Fixes & Performance Optimisations
  • Fixed issue where using undo after setting part of an assembly in scope unexpectedly reset the scope
  • Resolved problems in search and filter for library items (locations, codifications and types)
  • Prevented full property loading on browse panel open for improved speed
  • Resolved Z-fighting when dropping the section manipulator onto faces
  • Fixed incorrect behavior of “select” vs. “select directly assigned” in Library panel
  • Mobile: login screen now waits for user input before loading
  • Increased width of property set picker for better usability
  • Suppressed irrelevant “disable keep connected” messages when toggle is hidden
  • Prevented Browse Panel’s “Expand All” from triggering item reselection
Thanks for being part of Qonic’s journey! These updates are here to make your BIM projects easier and more connected. Ready to dive in? Get started with the new tools at app.qonic.com or watch our latest webinar to see what Qonic’s all about. We’re excited to see what you create!
