June Release Notes: More Control, More Clarity
With every update, Qonic becomes a stronger partner in your digital construction workflows. This month, we’ve focused on improving how you manage models, structure data and collaborate across teams.
Want to see it in practice? Check out this month’s release video:
Data management
Project library management: Libraries can now be shared across the entire project or linked to specific models. This gives you greater flexibility in how you structure and reuse information.
Split/merge models: You can now split or merge models by moving products between them—making it easier to reorganise project data or allocate responsibilities across teams. This is particularly helpful when working with IFC models, where managing separate models per discipline or deliverable can significantly improve clarity, control, and downstream coordination.
Create new (empty) model Need a clean slate? You can now create an empty model to start from scratch or use it for planning, testing or documentation purposes.
Accurate quantities
Version compare fixes: We’ve improved how quantity changes are tracked and displayed:
Removed elements now show quantity changes correctly
Opening elements are handled more accurately
Zoom and highlighting behave more intuitively
Stability issues when clicking or receiving notifications have been resolved
Negative quantity fixes: Resolved an issue where negative values could appear in quantity results.
Cloud-based collaboration
- Multi-model overview (UI): A new interface makes it easier to browse all linked models in one panel, streamlining navigation across federated setups.
Full-model slice improvements: We’ve improved the performance and stability of slicing entire models.
Optimised slice & subtract: Better performance when working with large selection sets, making common modelling actions faster and more responsive.
Platform & user interface
Browse panel enhancements: Report configurations and panel settings are now unified for more consistent browsing and reporting behaviour.
Measure tool fix: The “Calculate” button is now reliably active when quantities are present.
Zoom enhancements: You can now zoom out further, giving you more flexibility in working with large models or detailed layouts.
IFC export fix: Local placements are now correctly aligned when exporting to IFC, ensuring accurate positioning of components.
Type handling fixes: Created types are now properly added to the library and are easier to search during inspection.
Dashboard
Locations overview page: Access and manage the full spatial structure of your project more easily.
Library search: Quickly search through libraries directly from the dashboard.
Version compare in reports: Comparison values can now be shown directly within a structured report view.
Member linking in model access: You can now manage team access faster through direct links in the model access dialog.
General interface fixes
Sidebar titles are properly truncated
Alerts are limited to one per event
iFrame rendering is now more stable
Context menus behave more consistently on macOS
Redirect flows and error handling have been improved in multiple areas
Bug fixes
Fixed issue where duplicate product names caused problems in Inspect
“Apply” button in the Inspect panel behaves correctly
ESC now correctly cancels library item creation
Floor sorting now works even with identical names in different buildings
Fixed crashes when opening empty models via notifications
Various UI loading and error behaviours have been improved
Still working around your tools?
Too many teams still wrestle with rigid software, clunky exports or endless workarounds just to get the job done. We think it should be simpler.
Qonic is here to change how BIM works: fewer clicks, smarter automation and truly open collaboration. Just better tools, delivered monthly.
Features are already live, so if you’ve got a moment, jump in, create your account and give Qonic a try!
