Qonic August 2024 Release Notes
We are excited to announce the August release of Qonic, bringing you a fresh user interface, improved performance, and a range of new features and fixes to enhance your workflow. Here’s a detailed look at what’s new and improved in this release.
Cloud-Based Collaboration
Improvements
  • Model Access Rights: Default access rights now propagate to all members when uploading a new model.
Model and Data
Improvements
  • Property Management: Updated design for adding new properties.
  • Inspect Panel: You can now change the location, codification, and material directly in the inspect panel.
Fixes
Browse Panel:
  • Fixed issues when filtering on properties.
  • Resolved a crash issue while slicing.
  • Corrected property set filter functionality.
  • Sorted the property picker alphabetically.
Inspect Panel:
  • Confirm actions now work properly on enter.
  • Attributes now consistently display and confirm when selected.
Accurate Quantities
Fixes
  • Measure Tool: Disabled the calculate button when no calculator is chosen
User Interface
New Features
  • New look and feel: A sleek new look for our main user interface with floating panels for a more intuitive experience.
  • Redesigned Navigator: The redesigned navigator now includes a home button that resets sectioned or scoped views and automatically adjusts the zoom to fit your model.
Improvements
  • Inspect Panel: A cleaner UI design with added tooltip support for subselection, allowing you to quickly narrow down your selection set.
  • Browse Panel: Added visual feedback for entities when quickly selected.
Fixes
  • Error Feedback: Improved error messages when a procedure fails.
  • Dynamic Fields: Fixed dynamic fields now move correctly behind the main user interface.
  • Search Bar: Now remains in the correct position when resizing the window.
Modeling
Improvements
  • Material Layers: Material layers can now be added to all room-bounding walls at once.
Fixes
  • Snapping: Snapping is recalculated after manipulator rotation for better accuracy.
  • Window Movement: Fixed issues with moving windows that contain aggregate products.
  • Command Center: Resolved an issue where hitting enter was not starting a search.
Fixes
  • IFC Export: Resolved issues with exporting IFC models when the model name contains spaces or Unicode characters.
Dashboard
Improvements:
  • Libraries UI Consistency: Updated library selection to match the models and schedules.
Fixes
  • Classification Library: The library name now always shows in the codification overview.
  • Delete Dialog: Resolved a bug where the model delete dialog had an empty title
  • Mobile Support: Several fixes for the dashboard on mobile devices.
General
Improvements
  • Improved responsiveness for search, browse, and inspect functions, especially on models with many properties.
  • Reduced the number of loading screens during operations for a smoother experience.
Thank you for using Qonic! We’re continually working to bring you the best tools and experiences. Stay tuned for more exciting updates in future releases!
