We are thrilled to announce the July release of Qonic, including new features, enhancements, and fixes designed to streamline your workflow and improve your user experience. Here’s a detailed look at what’s new and improved in this release.
Improvements
- Slice: Improved slicing to keep BIM data consistent after slicing.
- Manipulator: Dynamically adjust the precision of the manipulator based on the unit.
Fixes
- Active Model: Only change active model on confirmation.
- Measure Tool:
- Resolved crash when calculating volume.
- Fixed issue where the measure tool is sometimes empty.
- Assemblies: Fixed issue where dissolving assemblies would delete windows and doors.
- Units:
- Use default length unit instead of meter for manipulator and procedures.
- Corrected the unit used when changing property values.
New Features
- Rhino Import: Move geometry closer to the origin.
- Non-Uniform Scaling: Support for non-uniform scaling in Rhino import.
Improvements
- Revit Export:
- Use a more reliable method for inner/outer face loops detection.
- Disable 3D view section box before export.
Fixes
- Rhino Import:
- Fixed bug with the counts of properties in inspect.
- Fixed bug with empty properties and corrected issues with scope and properties.
- No Geometry: Do not show products without geometry.
User Interface and Dashboard
Improvements
- Onboarding Videos: Added onboarding videos and updated explanations for new procedures.
- Browse Panel: Increased speed of the browse panel.
- Search: Speed and memory improvements for handling large search queries.
- Model List View: Truncated long model names in list view.
Fixes
- Inspect Panel:
- Fixed bug with the counts of properties in the inspect panel.
- Fixed bug with empty properties.
- Corrected issues with scoping and properties.
- Versioning: Disabled revert for revision files.
- Property Libraries: Fixed issue where editing a property would not close.
- Apps: Fixed issue where the mobile view was not shown for tablets.
- User Management:
- Ensured there is always at least one Project Owner as internal member.
- Allowed updates for invited internal project members with an Owner role.
- Display new organization invitees in the Internal project members list; those already part of an organization are shown in the external project members list.
- Public Sharing: Fixed sharing for multiple models.
Thank you for choosing Qonic! Stay tuned for more updates and improvements in future releases.
